Voip DIal-peer Problem pls. help
shamudra2000
My Head office PBX is connected to my Voice Router with 12 (VIC2-2E&M x 6 card) E&M Port and my Remote office-1 & 2 are the same.
My requirement:
1. HO dial to access code 60, then get a second dial tone and dial RO-1 PBX number (3000-3500)
2. HO dial to access code 80, then get a second dial tone and dial RO-2 PBX number (3000-3500)
Ext2000---PBX--E&M---HO-router-WAN---RO-1router---E&M---PBX---Ext3000
Ext2001---PBX--E&M---HO-router-WAN---RO-2router---E&M---PBX---Ext3000
Ho config:
voice-port 0/0/0 for RO-1
type 5
signal immediate
dial-type pulse
voice-port 0/0/1 for RO-2
type 5
signal immediate
dial-type pulse
dial-peer voice 100 pots
destination-pattern .T
port 0/0/0
dial-peer voice 101 voip
session target ipv4:172.16.1.2
dial-peer voice 200 pots
port 0/0/1
dial-peer voice 201 voip
session target ipv4:192.168.1.100
RO-1 config:
voice-port 0/0/1
type 5
signal immediate
dial-type pulse
dial-peer voice 300 pots
port 0/0/1
dial-peer voice 301 voip
session target ipv4:172.16.1.1
RO-2 config:
voice-port 0/0/1
type 5
signal immediate
dial-type pulse
dial-peer voice 400 pots
port 0/0/1
dial-peer voice 401 voip
session target ipv4:192.168.1.101
Problem:
In HO both dial-peer voip has same destination-pattern. My both remote office has same extension number. So, how can I separate the calls of RO-1 & RO-2 ?
Brandon Buffin
If you configure the PBX to send the access code along with the extension, then you could have dial peers such as:
destination-pattern 60....
destination-pattern 80....
Hope this helps. If so, please rate the post.
Brandon
Thanks for your reply. I have already solved the problem. Here is the config:
Ho config:
type 5
signal immediate
dial-type pulse
connection Tie-line 60
type 5
signal immediate
dial-type pulse
connection Tie-line 80
destination-pattern 70T
port 0/0/0
destination-pattern 60T
destination-pattern 75T
port 0/0/1
destination-pattern 80T
RO-1 config:
voice-port 0/0/1
type 5
signal immediate
dial-type pulse
connection Tie-line 70
port 0/0/1
RO-2 config:
voice-port 0/0/1
type 5
signal immediate
dial-type pulse
connection Tie-line 75
port 0/0/1
Here RO-1 come HO by access code 70 & RO-2 come HO by access code 75. All of my PBX have some 1, 2 & 3 digit extension number.
Pls. check my configure.
