Voip : ring back tone problem
177telecom
my voip network : As5400 + Pgw2200 ..... connect to PSTN . I have problem now : I used SIP software for make a call to PSTN : call to province A have ring back tone , province B have NO ring back tone. I compare the SS7 message between 2 province is the same. all ss7 info is the same .
anyone can help me to solve this problem
Thank
feberle
hi,
Try this command to simulate ring back tone :
voice call send-alert
Rdgs
try also this hidden command on ur dial-peer pots :
progress_ind alert enable 8
Rdgs
isahonen
You should look the MGCP messages between MGC and AS5400. I also wonder is that Province B send SDP-Body in SIP_Invite, this allows SIP early-media.
thank for ideas
- "voice call send-alert " : my configuration haved already
- "progress_ind alert enable 8 " : I added this command but nothing change , still no ring back tone.
- my network inluding H323 & SIP : only SIP (used Sip software client ) have no ring back , H323 everything OK .
I try to compare the Message GW --PGW : q931 :
province B : no ring back tone --> in q931 have no this "Progress Ind i = 0x8188 - In-band info or appropriate now available " , even i added progress_ind alert enable 8.
province A have above message --> have ring back tone
thank and Rdgr
