05-27-2003 06:53 AM
I have two network nodes (3662) running VoIP between them, but we are having a rare issue.
The calls are completed well, but after a lenght of time (not fixed) the call is terminated without user intervention. The calls could last from 2 minutes to 30 minutes.
The connection is a VoIPoFR. I am using FRTS with fragment, and ip rtp priority. I might think I having a QoS issue, so I used RSVP to reserve some BW to this calls. I configured RSVP as follows:
On the intf:
ip rsvp bandwidht 204 204
On the dial-peer:
req-qos controlled-load
Then I tried to use " show ip rsvp reservation", "show ip rsvp sender" and "show ip rsvp installed". Do I have to do anything else to see these reservations?
If you think it is not about QoS, what else could it be?
Thanks!!!
Alex
06-02-2003 10:51 AM
I would also save some bandwidth by enabling cRTP and VAD.
06-04-2003 04:49 AM
Hi Alex -
We'll need to see some debugs from the call disconnect to determine why the calls are dropping. Can you capture:
- debug voip ccapi inout
- debug cch323 session
during the time when the call drops?
Clay
