Wireshark Filter look not macth
meandaneth
Dear All,
Can you help me to look into wireshark filter as sip && ((ip.src==119.82.250.5 && ip.dst==202.83.198.7) || (ip.src==202.83.198.7 && ip.dst==119.82.250.5)). The filter look correct but when capture it won't and was capture with other ip which is unwanted.
Can you help me?
Your filter is OK.
I've succesfully tested this similar case with wireshark version 1.4.1 and 1.2.6:
icmp && ((ip.src == 192.168.1.10 && ip.dst == 151.1.1.1) || (ip.src == 151.1.1.1 && ip.dst == 192.168.1.10))
Divide your filter rule in 3 rules and make different tests:
1) sip only;
2) ip.src==119.82.250.5 && ip.dst==203.83.198.7 only;
3) sip && (ip.src==119.82.250.5 && ip.dst==203.83.198.7);
Good luck.
I use port mirror on my switch but i feel sometime this filter work but sometime not.
i used wireshark version 1.2.6. But atleast if it not mactch, it won't capture else ip. Any other option ?
Best Regards,
Daneth
