500DS Line Selection?
webbytech
Was curious if we could specify the line a key on the 500DS should use.  The reason for this is that theres different PBX's connected to this phone.
Example:
Key1: fnc=sd;sub=ext@$PROXY  (Use Line 1 of 525G2)
Key2: fnc=sd;sub=ext@$PROXY2 (Use Line 5 of 525G2)
Jaime Valencia
You probably want to move this to the SMB area.
java
if this helps, please rate
Thanks.  Its been moved :)
Dan Lukes
Use
  1. fnc=sd;sub=ext@$PROXY;vid=1
  2. fnc=sd;sub=ext@$PROXY2;vid=5
vid=# specifies the extension the sidecar key is associated with.  By default, it is Ext 1
Rate useful responses. It will help others to found solutions. Or mark thread as answered ...
