504G - lights on, cannot provision
foxlumber
Hi, I have a Cisco SPA 504G that I want to provision.  When I connect the switch to the phone I see 3 lights:
Red Microphone Mute button
Green Headset button
Green Hands-free button
Nothing on the display.  How do I get the display to show information?
John
7 Replies 7
testeven
Hi John,
Seems like you need to RMA the phone. I guees you cannot access the menu on the phone because the buttons are not working either, therefore you should get the phone replaced. If you want to place an RMA you need to open a TAC SR at:
http://tools.cisco.com/ServiceRequestTool/create/
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
foxlumber
Any other suggestions?
Not really, all indicates the phone is dead.
Tere.
Okay, thank you, Tere - If anyone else has a better solution on how to factory reset a 504G when the display is blank but the lights are on you can post a reply.
John
The problem is that the factory reset is done with the "setup" button on the phone, you have to  press it and scroll all the way down to menu #7 which says Factory Reset.
Tere.
My phone vendor thinks Cisco has a way to un-brick the phone.  Can you ask about that?
paolo bevilacqua
Wrong forum, post in "small business voice - SPA phones".
