640 - 460 .... UC500 & CME questions
dohaboy79
Hi Guys,
I'm preparing for CCNA Voice 640-460 exam and have 2 questions. One is realted to UC500 GUI configuration and the other one I think is related to CME configuration. I'm not sure if I can post them here.
Thanks in Advance...
That is fine. We will try to help, as long as they are not exam questions but rather general inquiries.
Marcos
The topology of the lab is attached.
the particular question that I have diffeculty with is:
Configure Hunt group so that all incoming PSTN calls always go to extension 3300. If extension 3300 is not available, route the calls to extension 4400. If both extensions are busy or not available then send the call to voicemail.
This is easily doable with CCA 1.9. Please refer to the latestt SBCS 1.4 First Look Lab Guide for instructions on how to configure Hunt Groups and related features:
https://www.myciscocommunity.com/docs/DOC-1525
Marcos
Brandon Svec
Level 7
Level 7
I would suggest that you check out CLN (Cisco Learning Network)
https://cisco.hosted.jivesoftware.com/index.jspa?ciscoHome=true
It is good place for exam and learning discussions. There is a section dedicated to CCNA Voice:
https://cisco.hosted.jivesoftware.com/community/certifications/voice_ccna
brandon
-- please remember to rate and mark answered helpful posts --
