7975 Power Save Issue
philipmoore
Just a quick note to see if anyone can correct the Power Save issue on some 7975's we have.  They used to work fine with our business schedule hours (open/close), however all of a sudden (not sure if we contributed anything) they don't.  If you reboot the phone when we are closed they will suspend and become active as per the time below, but again not our open time.  That is 9am - 5:30pm
From the Power Save Config :-
Display On Time
07:30
Display On Duration
10:30
Display Idle Timeout
01:00
To note, idle for 1hr doesnt work either.  Any assistance is appreciated.
3 Accepted Solutions
The config looks good, can you verify that you have the correct time on the phones?
I would make the following changes....
config t
telephony-service
service phone displayIdleTimeout 01:00
service phone displayOnDuration 09:00
service phone displayOnTime 08:55
service phone displayOnWhenIncomingCall 1
no create cnf
create cnf
Then, restart the phones.
Display on duration is the length of time the phone will be one starting at the display on time.  Phones on at 8:55 am, phones off at 5:55pm.
Let me know how this works for you.
We would value your input on the Office Manager end user tool (in beta now)
https://www.myciscocommunity.com/docs/DOC-12931
Actually, could you please use this download link for Office Manager?
http://www.cisco.com/go/officemanager
Marcos
11 Replies 11
Steven Smith
Level 7
Level 7
Can you provide your UC500 configuration?  Remember to remove passwords.
The time on and off for this configuration is stored in some service commands.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1108333
This parameters might be what you are missing.
Steven,
Thanks for the reply, I will check that out and revert with the update and if that is the solution.
Phil.
Steve,
Would you like me to paste or attach the running config?
I have it attached now, I can give you other configs if needed.
Phil.
config t
telephony-service
no create cnf
create cnf
Steve,
Worked a treat, and very well explained.  Made sense.
We are SMB users of this system, we find CCA OK, but in reality much of this depends on a high level of CLI, we would have some level of experience in this with CCNA but not for CCVP.
Thanks for taking the time to assist us here, have a good one.
Phil.
Marcos
Error showing up when trying to login using Office Manager - Error Reading Phone Settings...?
Philip,
Is the display dimming command the only one you have added using CLI? Office Manager, like CCA, does not like certain CLI and won't work for a non-CCA compatible system.
Marcos
No, we have had many commands added using CLI, both ours and more so Cisco Support have done many things via CLI.
That said, should we leave it?
Yes, at this point I would say don't use it. Sorry for that.
Marcos
