Ability to modify descriptions and line appearance through Variables
Jon Snipes
Beginner
Beginner
Is there currentlty the ability to use Variables to adjust the way descriptions and line appearances are written to the phone through user profiles?
I see that currently descriptions are defined as firstname lastname username extension.  The big place i would like more control over is for the line appearance.  if we could write into the template using predefined variables we could work around only the extension showing on the line.
ie
     %FIRSTNAME% %LASTNAME% - %EXTENSION%
daaron501
Beginner
Beginner
I would like to see this option as well. Anyone know if there usable variables already in place or is this being roadmapped? Not much use to put an entire profile with the same label/display. Having variables we can input for those profile-wide fields based on user imported information is beneficial.
DJ
Thank you for the feedback. Please keep it coming!
I will consolidate and discuss with the internal team
-Sunil
