05-13-2013 01:16 AM - edited 03-21-2019 07:20 AM
hello,
i work with the UC520 which is connecetd to 3 cisco IP phones. the cisco ip phone 7911 hasn't a button to define for CO line so how can i configure the line pool code for CO line knowing that i use the CCA for configuration. Thanks
05-13-2013 05:42 AM
With CCA I am not sure if you can mix CO Line and steering-digit configurations. However, it is not recommended to use the system as a "key system" anyway; it limits your design and while it is "familiar" for many small businesses it is not a great way to handle calls.
For what its worth this can definitely be done in CLI though.
-Dan
Please rate useful posts.
05-13-2013 06:25 AM
how can i change the CCA mode key system to pbx?
05-13-2013 01:34 PM
As correctly indicated by Daniel above, that is not recomended, meaning, do not do it unless you want bigger problems than the ones you have now.
