access code for co line
rchakchouk
hello,
i work with the UC520 which is connecetd to 3 cisco IP phones. the cisco ip phone 7911 hasn't a button to define for CO line so how can i configure the line pool code for CO line knowing that i use the CCA for configuration. Thanks
danplacek
Level 4
Level 4
With CCA I am not sure if you can mix CO Line and steering-digit configurations. However, it is not recommended to use the system as a "key system" anyway; it limits your design and while it is "familiar" for many small businesses it is not a great way to handle calls.
For what its worth this can definitely be done in CLI though.
-Dan
Please rate useful posts.
how can i change the CCA mode key system  to pbx?
As correctly indicated by Daniel above, that is not recomended, meaning, do not do it unless you want bigger problems than the ones you have now.
