11-12-2019 09:10 AM
Hi, I´m trying to configure a Cisco CP-8851, it´s supposed to be resset to factory settings, I´ve performed the resset holding # key and presing the secuence 123456789*0# and it seems to be with the factory default settings, but when I try to configure the phone in the web interface, and I click on Admin Login I.m asked for a password and I can´t acces the menu.
I´ve tried the passwords:
-admin
-Admin
-Password
-password
-Cisco
-cisco
- leaving the password field in blank.
The firmware version is sip88xx.11-1-1MSR1-1.loads
Thaks.
11-12-2019 01:16 PM
This means the phone is loaded with 3PCC firmware.
Cisco IP Phone 8800 Series Multiplatform Phones User Guide
Is DHCP Option 150 enabled?
01-24-2020 06:17 AM
Hi there,
If you're running MPP firmware, after a factory reset you should be able to login without credentials.
Can you please do a factory reset again and try accessing via: http://IP_ADDRESS/admin/advanced
Let me know how it goes.
06-12-2021 11:19 AM
Hello Pedro,
Not sure if you fixed this issue. If not, here is some information for you regarding your issue with your 8851,
Some Passwords to try:
cisco123
0000
00000
06-12-2021 12:10 PM
I also did find this for creating the credentials in CUCM
12-19-2023 07:41 PM
he firmware version is sip88xx.14-0-1-0201-171
