ATA boxes on the UC500
bjjensen
Is it possible to add external ATA boxes (VG202/204) to the UC500 and if so, does one fxs port count as one user
/Bjorn
Only ATA's supported are ATA18X and SPA8000. Also, the VG224 24 port FXS gateway is supported. Configuration notes and licensing considerations, on:
Integrating the UC500 with the VG224
https://supportforums.cisco.com/docs/DOC-9486
Integrating the UC500 with the SPA8000
https://supportforums.cisco.com/docs/DOC-9465
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
jamesnimmo
Hi there,
I'm trying to decide between purchasing the VG-204 and the Linksys SPA8000.
We only need another 4 ports, so I can't buy the VG-224.
Although it may not be officially supported, I am wondering whether anyone has any more information about whether the VG-204 will work with my UC520 box, and if so, will it be able to be managed through Cisco Configuration Assistant, like the VG-224 can?
I would prefer it to using the SPA8000 which doesn't have the auto configuration.
James
I don't believe the VG204 is supported in CCA.  I am sure that it could work, but the SPA8000 has been documented and proven to work.  I would use the SPA8000.
