04-17-2012 01:40 AM - edited 03-21-2019 05:40 AM
I use some some czech character in phone config file: Example:
<Default_Character_Encoding ua="na">UTF-8</Default_Character_Encoding> <!-- options: ISO-8859-1/UTF-8 -->
<XML_Directory_Service_Name ua="na">Centrální adresář</XML_Directory_Service_Name>
<XML_Directory_Service_URL ua="na">http://10.76.66.1:83/webapp/cisco_dir_search.py</XML_Directory_Service_URL>
And it works ok in FW 7.4.8a on display is correct czech chars "Centrální adresář", but not works in 7.4.9a 7.9.4c and new 7.5.1a too. It shows something as "CentrÅilnå_ adres~aiÅ>)"
Is some solution how to fix this ?
06-10-2012 03:37 PM
It is firmware bug. ISO-8859-1 encoding is used ignoring Default_Character_Encoding value.
You can encode "Centrální seznam" as workaround instead.
But my recommendation is simple: just stay away from national characters at all.
11-22-2012 02:50 AM
This is not not solution, our customers want full czech support, phone have UTF-8 characters in czech menu ok, in xml ok, only string from provisioning is bad. It was completly ok in older FW. Now we have 7.5.3 FW and it still have same problem. Cisco support for their products is horrible.
02-02-2013 02:07 AM
02-14-2013 07:21 AM
Well the problem persists in 7.5.4. Staying away from national characters in a good joke, it's 21st century, wake up!
02-14-2013 07:57 AM
Have you beeter advice for us or not ?
02-14-2013 08:01 AM
For us myself included? No, except for yelling at Cisco. I was just bitten by this, new phones came with 7.5.4;(
02-14-2013 08:25 AM
It may help in the future.
But you denounced advice that is applicable today, so I wished you know something better I can do just now.
07-09-2013 05:17 AM
It is fixed in new FW7.5.5, thank you Cisco for "quick" repair
