UC 540 phone system was installed at our location about 10 months ago. There are two locations with two Sonicwalls in place, and we went through hell to get the phones working at both locations. It took many months for the local reseller/installation...
Hi, I just purchased a Cisco SPA 303 and I am trying to get it set up with skype connect. I can't seem to figure it out. Any help would be greatly apprieated. Thanks,Jason
We have a UC320W with firmware 2.3.2 firmware.we have 2 analog trunks coming in to ports 1& 2 of the FXO ports and are connecting to shared FXO ports available to all phones.I've tried testing the FXO ports with the internal tests and they appear per...
Cbeyond apparently updated something on their end and our system stopped working. We added the outbound proxy setting and are able to place outbound for 23 seconds before being disconnected; inbound doesn't ring at all. Proxy Server (primary) sipco...
I'm trying to get a SPA8800 to register on a UC540 and i cannot figure out what credentials I need to use. I've created an extension in the CCA under add phones using the MAC address and selected ATA as the phone type. I've tried every combination i ...
Hello,I upgraded two systems to 8.6.0 and now I cannot access the http://10.1.10.2/ccme.html webpage to change extensions and configure phones. Did the url move? The are for some older customers so CCA is not an option on these anymore, I ...
I need to create a Cisco SmartNet quote for a UC560 and I'm not sure which option to choose. It needs to be 3 years, 24x7x4, and preferrably onsite. Can someone give me some guidance as to which option to select from the drop down box in the quotin...
CCA 3.2 adds a new feature allowing you to separate the VPN and inter-site dialling, which is a welcome change, as many of our customers have an MPLS network and don't require the VPN.While this is great, most of my clients use 3-digit inter-site ext...
Hello,I am running a UC560 and we are unable to dial internationally. Specifically we are trying to call Mexico and we receive a fast busy signal on the phone and the SPA504g handset shows "unknown number". The number I am calling works fine from a c...
Hi all,we are facing a problem with codec negotiazion with SPA2102 and SPA122. The firmware version are the latest available for the two platform.This is the scenario:User A makes a phone calls via SPA2102 or SPA122 to User B on PSTN. In the INVITE t...
There have been some questions around BE6000 ordering for HA or migrations. For the purpose of HA or Migration, the software starter bundle is NOT required. you only need to purchase the server bundle : BE6K-ST-BDL-K9=Case 1: customer already have...
Hi All, we have a UC540 installed with remote VPN phones, after changing the exyernal ip address and deleting and recreating the NAT rules, the computers behind UC have internet connection , but the UC itself has no internet connec...
I have a situation where I'm running firmware version 7.5.3 and need to change from an "Asterisk" Server Type to a "RFC3265_4235" per the PBX manufacturer's recommendation. The PBX manufacturer is not supporting firmware version 7.5.4 and cannot upgr...
