BE3k solution check
henie
Hi Team,
Customer has a head office with 12 extensions and 27 branches mainly with 1 extension.
I am looking at a BE3k with an ASA55xx as a VPN concentrator to terminate the tunnels either directly from the phones, or from the remote site routers.
Can you please confirm if above solution will work ?
Henry
sanjsinh
Direct VPN from phones is not supported and is a feature on the roadmap. But you can terminate the VPN tunnels from remote sites to AS55XX on central site. Your branches with single extensions will fall in Teleworker site.
Thanks Sanjay.
How many teleworker sites does BE3K support and what are the other limitations ?
Henry
There is one teleworker site. It is like a catch-all site. Any phones whose IP address is in a subnet which does not belong to central site or remote site, will fall into teleworker site.
