Call to sip amplifier go out through sip trunk
Barry Hunsinger
I am re-wording this question. I have a cyberdata sip endpoint amp. It is registered, connected, has an extension. when i dial the extension it gives a fast busy. When i check the logs it shows that the call is going out through the sip trunk to our ITSP (nexvortex), where of course it fails. How do I create a dial plan to keep it inside?
David Trad
Hi Barry,
I think you have made the mistake that many of us made the first time we looked at a SIP amplifier
Firstly you do not want to use the SIP register for this, actually you want to use a SIP-DN which falls under your global DN registration, this then creates a SIP extension much like the SCCP extension (Which I believe Cisco will move down this path shortly).
When you create a SIP-DN it acts and behaves like a normal extension, and it also ensures that it will correctly hang-up once the user closes the circuit as it wont need to wait for a response back from the unit.
Here is the sticking point CCA does not support creating this as far as I am aware (In version 3.2), maybe the beta version 3.2.1 might?? So you will need to do this via CLI and this may get you into some trouble with SBSC if you are not Express certified, so maybe you can log a configuration assistance with SBSC on this and see if they will assist you with configuring this up.
What I can tell you is that this is the best way for it to work, creating a SIP registration like you would with an ITSP requires further configuration such as Dial Plans and Translation rules/profiles etc...etc.. Not the most ideal way to do it
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Thanks David. I will try to sbcs to cooperate. They don't like to help support 3rd party products. They may be willing to help create a sip-dn, and then I can take it from there.
I just called sbcs. they claim I don't have cli support. I didn't know that that was an option. Does anyone have the cli commands to create sip-dn?
Hi Barry,
I am always obliged to help others out, however I must disclaimer the following:
  1. You do this at your own risk
  2. I am not responsible if you get denied support by SBSC due to the CLI changes you implement
  3. You will most likely make your SBSC contract void or in a non support configuration
Sorry if that sounds harsh, but I just need you to be clear that what I am about to do is to purely to help you out because I know that you are stuck, and that you realize what you are doing is not within your certified capacity under Cisco's terms and conditions (Even though many of us may not agree with these terms in whole).
voice register global
mode cme
source-address port 5060
max-dn 5
max-pool 5
dialplan-pattern 1 XXXXX... extension-length 3
authenticate register
date-format D/M/Y
file text
create profile
voice register dn 1
call-forward b2bua noan 399 timeout 45
number 300
allow watch
name Amp
label Amp-300
voice register pool 1
id mac 0001.0002.0003
type
number 1 dn 1
dtmf-relay sip-notify
username amp password 1234
allow watch
codec g711ulaw
NOTES:
  • The above configuration was done on CME version 4 & 7 not 8 so quite a few things might have changed since as a bit changed between version 4 and 7
  • This may not work the first time and you may need to play with it until you get it right, the above configuration took almost a day to get right for the SIP payphone I had to integrate into the system
  • You need to make sure that the settings on here matches that of the SIP end point, no match means no work and play
  • For the sake of it, THIS is not going to be a supported configuration for you and will most likely put your system out of scope PLEASE understand this before you impliment, and if you are concerned about this then do not proceed.
Good luck, and I highly encourage you to sit the Express UC certification exam before it expires (Not sure what it is being replaced with) and get yourself covered for these types of changes. I understand why Cisco are doing this, but what I don't understand is how their policy leaves an entity high and dry and denied basic support because of a system that is not fully functional and capable of supporting the UC (CCA I'm talking about here).
Cheers,
David.
