CallConnector dial locations
apedder123
I'm just setting up CallConenctor Server for the first time. Got a small problem.
When I select Dial Plan Settins and go to the drop down box  to select the clients local area, it isn't there.
Should be United Kingdom - 1279 (Bishops Stortford).
How can I get it in?
Adam
Alberto Montilla
Dear Adam;
I will get an engineer to help you on this.
Alberto
Hi Adam,
It is in Configuration Manager-Setup Router and Servers-Location Management (1 up to the bottom left corner).
Hope this helps. If needed, I can setup a quick webEx session and work with you to get this configured and running. Please provide us your email address, date/time and send to alias at cs-callconnector@external.cisco.com or ucc-beta@external.cisco.com
I'll get back with a time once I know where I'm going to be.
Just to be sure though - I've been where you have instructed me, but our local area (0)1279 is not in the list. I think it has been missed off somethwere!
Don't worry - I couldn't see the wood for the trees.
Saw the Add option now and I'm done.
Adam
