Caller-ID info in VM Notifications
Greetings all,
Does anyone know if it is possible to change the "message from:" field information in a CUE voicemail notification email?  The caller number comes across but not the name.
Thanks.
2 Accepted Solutions
Saurabh Verma
Level 4
Level 4
The "Message From:" field will include name only for internal callers - i.e. if there is a match against the internal CUE database.
-Saurabh
Hi Michael,
No, CUE only has a database of internal users that have mailbox on the system. AFAIK, there isn't any workaround. I will check with CUE team to see if they have any enhancement on their roadmap.
Saurabh
Saurabh Verma
Level 4
Level 4
-Saurabh
Thanks for the reply.  How can that DB be populated?  Or can the CUE use an external CID DB such as VeriSign?
Hi Michael,
Saurabh
Well that is unfortunate.  I have a few clients that are complaining about that issue.  I hope the Cisco seriously considers make some changes in that area of the CUE among others.
Thanks for your time it is appriciated.
