Calling-Number command not working
tknapp
UC520 running uc500-advipservicesk9-mz.150-1.XA
I have a line (423) set to CFA, when the number is called it sends out the local lines number as calling party.
I have changed the calling-number to initiator and local.
intitiator causes this to happen.
Calling Party Number i = 0x2180, '7202832423'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '3037078037'
        Redirecting Number i = 0x00008F, '423'
It is sending out the local lines number 7202832423 not the original calling number of 2084420136
setting it to local causes this to happen
Calling Party Number i = 0x2180, '72028327202832423 <-----need to be 208-422-0136
423'   <------need to be 7202832423
Any help would be appreciated, thanks
7 Replies 7
Marcos Hernandez
You need to manipulate a couple of translation rules for this to work. Could you post your configuration? Don't forget to remove passwords and other confidential information.
Marcos
I have attached a config from the unit.
If more config is needed please let me know.
I would also like to know what reference is used
Thanks.
Just wondering if you ever obtained a solution to your problem, and if so, could you share it.
Thanks.
I will post my comments shortly. Sorry for the delay everybody!
Marcos
In the configuration that you posted, could you try changing the translation profile of your POTS dial peers to "PSTN_CallForwarding", instead of what's currently configured?
Let me know.
Marcos
rule 15 in this translation pattern was causing the issue:
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-rule 4
rule 1 /423/ /7202832423/
rule 2 /444/ /3037383444/
rule 3 /^44\([0-1]\)$/ /303738344\1/
rule 4 /445/ /3037383445/
rule 15 /.*/ /7202832423/
I was told rule 15 was causing the issue.  which makes sense.
I did a clean install on another unit and did not try to get fancy, very raw and simple.
voice translation-rule 5
rule 15 // //
translate calling 5
The second set is what was created and no problem with number Caller ID.
Thanks to my co-worker Andy Z.  for finding the original part.
Also thanks to all the folks who replied, nice to share the fun!
I have the same problem.  Could you share what translations are needed to make this work?
Please refer to the attached config file.
Thanks.
Rich
