11-26-2012 04:20 AM - edited 03-21-2019 06:39 AM
Calls made to toll free numvber not workung in uc560.
Please find the attached Configuration file .
11-26-2012 08:35 AM
I just went through this.
What is your outgoing callerID set to?
If I set our outgoing callerid to a 1-800 or 1-855 (i.e. a toll free number) it would not connect to any toll free numbers I was calling. As soon as I changed it to our local number its worked since.
11-27-2012 09:06 PM
sorry i didnt get you ...if you dont mind can you check the commands and let me know what commands i need to add extra..or what i need to chnage actually.
11-28-2012 06:17 AM
I used the CCA do make this change.
Open up the CCA, configure - telephony - dial plan - outgoing.
See what your outgoing callerid is set to.
Hope this helps.
