07-19-2011 02:36 PM - edited 03-21-2019 04:22 AM
I want to get some Cisco Cameras to test out Cisco video systems and want to make sure that what I purchase will work with the uc320 when they begin supporting them.
Does the roadmap for the uc320w know which cameras I can safely purchase today that will work with the uc320w.
Do you have a beta program that I can participate in to be an early adopter of the new release coming out (I heard Sept 2011)
Scott
07-19-2011 03:09 PM
Hi Scott,
Have you thought about using the PVC2300 Camera for this?
They should work without a problem, just make sure you assign the right IP address to them and either plug them into a PoE enabled switch, or if putting them onto a Power Pack, then plug them directly into the back of the UC-320W, this should work for you
Cheers,
David.
07-20-2011 08:20 PM
I think that the issue may be that (from what I understand), I am not allowed to change any of the settings on the spa525 phones, as they are under the control of the uc320. I may be off on this, but what leads me to think this, is that I wanted to use a third party softphone that integrates with Outlook and was told that the uc320 restricts how that software would work with the phone, so at that time, I could not make any changes to the spa525 that would not get overwritten by the uc320.
I am not sure that I am correct here, but I will try it. I have a PVC2300 on order and will try when I get it in play.
Can anyone from support comment on whether this has been done with the uc320, the spa525g2 phones and a PVC2300.
Scott
07-22-2011 01:53 PM
Hi Scott,
There is a current pending feature request to support PVC2300 camera provisioning for use with a SPA525 phone for video. Right now, you are correct, the fields to allow a SPA525G to communicate with a camera are locked.
Chris
07-27-2011 02:51 PM
IP Camera support with the SPA525G2 and UC320W would be a HUGE HUGE selling point to small law and medical offices! I'm looking forward to this!
07-24-2011 02:58 PM
Hi Scott,
If putting the PVC2300 on the UC320W then the only way to view the camera at the moment is via the Web GUI, not sure if this is suitable for you.
Cheers,
David.
