04-25-2012 12:09 PM - edited 03-21-2019 05:42 AM
Hi.Is It possible to setup a second wan Interface for redundancy on the uc540w?
If It's possible , will licensing restrictions also be an Issue ?
Solved! Go to Solution.
04-25-2012 03:36 PM
Yes it's possible, without licensing restrictions.
04-25-2012 10:34 PM
Hi There,
As Paolo has suggested, yes it is possible but it is not recommended and it is not a support method by SBCS, if you have however a SmartNet contract instead, then go for it
Other than that a low cost dual WAN by Cisco is a better alternative, something like this one HERE this has been used by quite a few here on these forums.
There are other ones out there with Wireless such as the 540 series, they are pretty damn good and I have used them many time as well, perfect for Ethernet hand off's.
Cheers,
David.
04-25-2012 03:36 PM
04-25-2012 10:34 PM
Hi There,
Cheers,
David.
04-25-2012 11:53 PM
Hi.Thanks for the Info.Thats a very decent price.
04-26-2012 02:06 PM
Hi There,
The RV range of products is designed for small business, where the ASA is
really designed for small to medium sized enterprise clients.
Cisco have other similar products that can do the same as the RV can, but I
believe the RV series has become some what popular and is a supported
method with the UC-500 series.
On Apr 26, 2012 4:54 PM, "Reprovoid" <
04-26-2012 02:17 PM
Already purchased two thanks to you! Ask for a commision! We have an ASA 5505 but It's a basic license.The upgrade for two ISP's seems a bit steep.
04-26-2012 02:31 PM
Hahahahaha love the humor
Ask for commission he says, that is gold :-$
Mate I hope it works as planned and is easy for you to do, good luck with
it
On Apr 27, 2012 7:17 AM, "Reprovoid" <
