Can't ear calling ext from ip phone to pap2t or rt31p2
krcarlos
Hello all,
I need help with configuration between internal extension
router wrt54gs tomato, switch bsfr41
spa9000 v2 (and V1) DMZ
pap2t (analogic phone), rt31p2 (analogic phone)
and 2 ip phones swissvoice ip10s.
all in the same network
all the phones can dialout/receive call through betmax service provider.
The only problem is 1 way communication from the ip10s phone to either pap2 or rt31p2
   ip10s calls the pap2 or the rt31p2, the receiver phone will ring but will not ear.
and all others combination will work fine
any idea about how to fix this? thanks
Alberto Montilla
Dear Sir;
Would need network traces to understand what is happening.
Alberto
Syslog from rt31p2 calling from and to the swissvioce phone:
[0]Off Hook
2. Report digit 1 (1)(40 ms)
2. Report digit 0 (1)(40 ms)
2. Report digit 5 (1)(40 ms)
Calling:105@192.168.1.130:6060
[0:0]AUD ALLOC CALL (port=16408)
[0:0]RTP Rx Up
CC:Ringback
[0:0]RTP Rx Dn
[0:0]ENC INIT 0
[0:0]RTP Tx Up (pt=0->c0a80165:50000)
[0:0]RTCP Tx Up
CC:Remote Resume
CC:Connected
[0:0]RTP Rx Up
[0:0]RTP Rx 1st PKT @16408(3)
[0:0]DEC INIT 0
[0]On Hook
[0:0]AUD Rel Call
DLG Terminated
[0:0]AUD ALLOC CALL (port=16410)
[0:0]RTP Rx Up
IDBG:sc-0 IDBG:rs:12 IDBG:sc-0 IDBG:rs:12
[0]Off Hook
[0]CID interrupted
[0:0]RTP Rx 1st PKT @16410(3)
[0:0]DEC INIT 0
[0]RegOK. NextReg in 58 (1)
[0]On Hook
[0:0]AUD Rel
Call Sess Terminated
Not sure if it helps , thanks
Not much ;-), I need SIP info as well. Can you take traces with ethereal or wireshark?
Alberto
