Cannot dial a 10 digit number, call gets cut off after 7 digits
carson-wells
Customer has an issue where 10 digits dialing to a certain number doesn't work.  The number does not require a 1 or 0.  When you dial the area code + the number the called digits stop at the first seven.  I've included a snippet of my dialing peers.  If I take out dial-peer voice 70 it works.  But then I'm unable to dial a number with 7 digits, I have to include the area code on every call.  Thanks in advanced.  – Carson
dial-peer voice 70 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **7-Digit Local**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_FXO
description **10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
forward-digits 10
no sip-register
9 Replies 9
Hi Carson,
Change the destination pattern on dial-peer 78 to this:
destination-pattern 91[2-9]..[2-9]......
You will need to dial a 1 though.
Marcos
Thx Marcos for the quick response.  I've tried dialing the number with a 1 and you get the standard ATT message - "This number does not require a 1 or 0 when dialing..."
I have this dial-peer as well
dial-peer voice 72 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 5
forward-digits all
no sip-register
OK, you have a situation in which you have 7 digit local dialing and 10 digit local dialing. What are the prefixes for 10 digit local?
It's 936 and I've tried a dial-peer with 936 and it still uses my 7 digit dial-peer (70).
Do your 7 digit numbers in your area start with 9? If not, do this:
trunkgroup ALL_FXO
preference 5
destination-pattern 9[2-8]......
forward-digits all
no  sip-register
No, I don't think so.  I'll try that when I'm back onsite and I'll update this thread.  Thx.
JOHN NIKOLATOS
Level 3
Level 3
Try this:
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
destination-pattern 9T
forward-digits 10
no sip-register
John Nikolatos
www.niktek.com
I have a similiar issue with a system in the 231 area code - they have a list of "local" numbers in the 616 area code which they have to dial the area code + phone number - 10 digits.  Not sure how I would create a dial peer for this.
The local outbound calling area in the 616 is
616;223;Grand Haven;MI;;;;;
616;296;Grand Haven;MI;;;;;
616;402;Grand Haven;MI;;;;;
616;414;Grand Haven;MI;;;;;
616;502;Grand Haven;MI;;;;;
616;529;Grand Haven;MI;;;;;
616;576;Grand Haven;MI;;;;;
616;604;Grand Haven;MI;;;;;
616;607;Grand Haven;MI;;;;;
616;638;Grand Haven;MI;;;;;
616;743;Grand Haven;MI;;;;;
616;842;Grand Haven;MI;;;;;
616;843;Grand Haven;MI;;;;;
616;844;Grand Haven;MI;;;;;
616;846;Grand Haven;MI;;;;;
616;847;Grand Haven;MI;;;;;
616;850;Grand Haven;MI;;;;;
616;935;Grand Haven;MI;;;;;
My existing entries for 7 + 11 digit dialing:
dial-peer voice 7 pots
trunkgroup Analog
forward-digits 7
dial-peer voice 11 pots
trunkgroup Analog
forward-digits 11
I am not able to dial "1616" for numbers in the above list of area codes as it will also state the "1" is not necessary.  Any information would be greatly apprecitated.
