CCA 1.9 Issue/SIP Trunk
amir
Has the CCA 1.9 & sip trunk error issue been resolved with the new 1.9.1 TBD release yet?
Hi Amir,
Which error exactly are you referring to?
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
BTW; Tomoo is aware of this issue (CCA 1.9/SIP Trunk). The error comes up when I configure a UC520 router for SIP Trunk (Cbeyond) service. Basically, immediately after the voice parameter config read completes, the error show up in the Devices window and the SIP Trunk turns red indicating error. If I switch to CCA 1.8, there's no problem and I can continue configure the SIP Trunk and register with the ISP.
Tks., Amir
Hi Amir,
CCA 1.9.1 has the fix for the Cbeyond SIP trunk interop issue. It is slated to post to CCO tomorrow. If you need to get an engineering image in advance, please unicast me.
Rgds,
Tomoo
CCA 1.9.1 is now on CCO. Details below:
https://www.myciscocommunity.com/docs/DOC-3400
