06-21-2009 09:53 PM - edited 03-21-2019 01:13 AM
06-22-2009 05:22 AM
CCA uses a combination of multiple programming languages and technology, Java being the predominant one. Some sections like the Dashboard, Wireless Setup Wizard, have incorporated some Flash content using Flex.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
06-22-2009 09:54 AM
It's possible have source ?
for convert your CCA Windows to OS X I have 2 Engineer JAVA...
06-22-2009 10:10 AM
Cisco does not distribute the source code for CCA.
Marcos
06-22-2009 10:50 AM
And it's possible Cisco watch for convert to an other OS. I work with OS X, Solaris and IRIX.
convert software with Cocoa it's very simple.
I use this : http://www.lithiumcorp.com for manager all servers system. And install Windows it's not realy secure.
06-22-2009 11:20 AM
There are no plans to port CCA to other Operating Systems at this point in time.
Marcos
06-22-2009 11:48 AM
And you you thinks it's possible Cisco dev add-one for http://www.codeweavers.com/products/cxmac/ support your software ?
06-24-2009 07:27 PM
Crossover request:
http://www.codeweavers.com/compatibility/browse/name?app_id=5912
