Hi!
CCA went into confusion because I dared to order as I would like the buttons of telephone!
In practice, on the telephone with the extension 205 I put the buttons 1 to 4 to 'monitor', respectively, for the extension 201, 202, 203, 204 and then on the button 5 I put a 'normal' line with extension 205.
When I returned to the CCA, I noticed that something was wrong ... going to the menu 'voice' can no longer find the extension 205 with the correct name and it was very difficult to return to the setup correctly. The 205 was overlaid with 201, and now I suspect that the configuration is messed up ...
What is this? Another limitation of CCA or an idea was unhealthy to want (to order several buttons) !?
Note: I only used the CCA to make trouble :-) I would have expected to rearrange the buttons did not show if this could have consequences on the configuration or the same CCA!
73,
Arturo
