Change tone when calling wrong number
svein.olav.olsen
Beginner
Beginner
Hello!
Anyone know how to change the fast busy tone when calling wrong number?
And one more question!
When starting to call a number and you have to look for the rest of the number, th display on the phone turn back to default, is there a posibility to change that time?
regards
Svein
David Trad
Rising star
Rising star
Hi Svein,
I do not know if this is possible on the UC, as far as i am aware this is controlled by the carrier, it is their switching equipment that usually dictates this.
I believe this is under the telephony-service section, not sure where to find this in CCA but it is to do wit the digit input time out, by default this is set to 5 seconds, on the odd ocassions i get asked to push this out to 10 seconds when you have real fussy customers :)
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Recognize Your Peers
