09-17-2013 08:34 AM - edited 03-21-2019 07:46 AM
Is there a way to change the sequence number for the phones hooked up to a uc520?
Ex. When an incomming call is received, ext. 201 is the default line if no extension is selected. Can I make ext. 204 the default line instead? if so, how?
Thanks.
09-17-2013 11:03 AM
Are you the end-user? Are you using CCA ?
09-17-2013 11:06 AM
Yes I am using CCA.
