Changing UC520 LAN IP address
rventura
I'd like to change the LAN IP address of a UC520 without going through the voice wizard.
I found the instructions that Marcos posted here, https://www.myciscocommunity.com/message/7677#7677. This should work, but the IP address I want to use is on the same subnet as the default IP address.
I want to change from 192.168.10.1 to 192.168.10.x. Any help would be greatly appreciated. Thanks.
Saurabh Verma
Level 4
Level 4
I don't think there is an easy way to do this in CCA. You may want to use CLI to change the IP address. If your UC 500 has built-in wireless AP, you will need to change the IP address under the BVI 1 interface and if it doesn't have a built-in AP, you will need to make the changes under the vlan 1 interface.
interface BVI1
description $FW_INSIDE$
ip address 192.168.10.1 255.255.255.0 <== change this
ip access-group 102 in
ip nat inside
ip virtual-reassembly
interface Vlan1
ip address 192.168.10.1 255.255.255.0 <== or change this
ip nat inside
HTH,
Saurabh
Thanks.
I just wanted to clarify for Partners reading this thread that there is a CCA way to do this, but the Telephony Setup Wizard only works when you first start configuring a brand new system, or one which you factory reset.
I think we can all agree that with a site survey in advance of deployment, the TSW method makes sense & works for most cases....
