07-08-2011 02:46 AM - edited 03-21-2019 04:19 AM
Is anyone knows the way to change the english menu in the Cisco 303G2 phone into italian language?
Any suggestion would be helpful.
Thank you in advance,
Gergely
07-08-2011 03:34 AM
Dear Gergely,
Please find the XML dictionary files at this link:
https://supportforums.cisco.com/docs/DOC-11463#comment-7107
Select the version matching your FW version and you'll find the Italian XML dictionary file.
Put the English and Italian XML files into the same folder which will be the root folder for your tftp server (like tftpd32).
Then you'll need to configure the IP phone in Admin login, Advanced, Regional tab:
Dictionary Server Script: serv=tftp://aaa.bbb.ccc.ddd;d0=English; x0=spa50x_30x_en_v746.xml; d1=Italian;x1=spa50x_30x_It_v746.xml
Language Selection: Italian
Default Character Encoding: UTF-8
aaa.bbb.ccc.ddd is the IP address of your tftp server.
Hope this helps, and please do not hesitate to post if you need further assistance.
Best regards,
Zsolt
07-08-2011 03:48 AM
P.s.: This process has to be done only once, the IP phone will retain the new language untill factory reset.
07-08-2011 04:02 AM
I give it a try, the phone is not here, so i have to do it remotely.
If i cannot check it today i send answer after the 25th of July.
Thanks/Köszi!
Gergo
07-08-2011 04:17 AM
No problem, also for your kind information it is indeed possible to use FTP or HTTP instead of tftp for transferring the XML files if that would suit you better for a remote configuration.
Best regards / Üdv.,
Zsolt
07-08-2011 04:29 AM
Ok, we can use any of these. When i get the remote access i check it.
Thank you for your kind information.
Best regards / Üdv,
Gergő
07-08-2011 05:43 AM
The phone is just working fine. A question, if i leave the settings in the phone, and i stop the TFTP server, the phone after reboot will be still italian, or it loose the setting because of the missing TFTP file?
Thanks / Köszi,
Gergely
07-18-2011 12:57 AM
Glad to hear it worked out for you. The phone uses the TFTP server only when it downloads the selected language XML for the first time so once you have Italian on the phone you won't need the TFTP until you factory reset the IP phone.
Regards / Üdv.,
Zsolt
10-15-2012 02:32 AM
Sorry, I've followed theese instructions too, to upgrade italian language. But after all in the phone menu at the language option, i can choose english/italian, but after selecting Italian and save it, the phone lang don't change. I try to restart but i can see ever english language. Any suggestion?
