Are all the 7900 series IP phones capible of handling more than 2 concurrent calls? What about the 6900 series?Thank you.-Tim
i have a new client with a uc540 setup and there is 3 phones. 1 phone offsite at a remote location with an spa525g2 with ssl vpn, and when she (the remote user) calls someone every so often the conversation stops, i called her to see how it was worki...
Hi Guys,Is it possible to automatically remove voicemails after they expire? We have them on GDMs and the GDM becomes full, we stop getting voice to email. They expire after 15days, so we'd like them to be automatically deleted after this date.
We have a UC560 with a front desk admin that transfers calls to the users.Some of these calls end up in voice mail.When the user retrives one of these voicemails, they get a lengthy system recording preamble along the lines of "Call transfered by XXX...
I have a customer whose Voicemail-to-Email is not working.I was able to locate the error below in the system logs -- but it's too vague to really tell me what is going on.Anyone have any insight into what this means?Jul 2 10:40:21 UC320W user.debug ...
I’ve got a SPA504G with Asterisk PBX and broadband.com SIP service. I can recieve calls fine on the handset, but when I make outbound calls, about half of the calls have one way audio or no-way audio. When I have audio problems, I can hit the hold bu...
Hello.BE 3000 (8.6.3), Russian packInternal GW (E1 PRI) conected to PSTN. For calls (local,mobile, toll free, long distance) the operator require only pass 10 digits (format is {area code}{local number})By default the BE 3000 pass 11 digits as the fi...
UC540SP 8.6Hello,How do I set up email alerts that inform a user that they got a new voicemail?Thanks
Hello,I have a cisco 887W router with several SPA504 phones that are not able to fully register to send and receive calls, inbound the phones will ring but no audio heard either way.At the moment I have NAT'd udp 5060 direct to a single phone and tur...
UC540SP 8.6.0Can the Intersite Dialing Prefix be different for the sites?For example, can Site 1 use an Intersite Dialing Prefix of '4', and Site 2 use an Intersite Dialing Prefix of '7'?Or does the Intersite Dialing Prefix have be '4' for both Site ...
HelloHow can I calculate the amount of calls that the BE3K can handle at the same time? The datasheet does not talk about maximum trunks supported by each BE3K.Thanks,Adolfo
I have a Cisco/Linksys SPA 962 Small Business IP Phone that I need help configuring. The device was previously configured for a different workstation and I need to add the new SIP Credentials for my new VOIP provider. Let me say that I am a busines...
Hi I have UC320 installed and am in an area that is both 5 number and 6 number digit plans.I have set the system to 6 digits, but then finding we cannot dial locally 5 didgits as I presume the system is waiting for the 6th.Is this correct or is my is...
Hi Team,On a UC-320W Deployment I have done not long ago the system was placed into "Blend Mode" and I assigned a Line to a button (KTS Mode), this was ok, until I was told that the doctors did not want all in-coming calls to ring on their phones whi...
I have just switched internet providers and they gave me different static IP's. Once the change happened, I was no longer able to access the UC520 via web browser or CCA. Previously, I used 10.1.10.1 to access Web UI. I have connected via console ...
