Cisco 9971 SIP security Issue
cameronalan
HI,
I am looking for a little help with this all input is welcome.
I have a UC540W and a number of endpoints all are 79xx series using sccp. only one is a 9971 sip handset.
I have configured the unit using the Cisco configuration assistant version 3.2, this created the base and then I have manually altered parts of the config.
ITSP - VoIP Unlimited
With the config in for the 9971 to conenct the phone works perfectly but we keep getting toll fraud. I have tested with the xlite client installed on a pc at my home and I can connect and call numbers internally and external to the business with out using any auth information.
I then added the line below to the voice service voip (bind control source-interface BVI10) and the external client can no longer compleate a call but can still try and dial as it rings but drops the call before it can compleate.
I also have entered the trusted IP address which in this case is one of the servers at VoIP Unlimited. but this hasn't helped.
I am not sure how else to lock this down and stop people gaining access to this.for now I have removed the endpoint from the system and will set it back up once we get a solution to this. (may be somthing I have overlooked)
voice service voip
ip address trusted list
  ipv4 91.151.2.130
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-throug
h g711ulaw
sip
  bind control source-interface BVI100
  registrar server expires max 3600 min 3600
  localhost dns:sip.voip-unlimited.net
  outbound-proxy dns:sip.voip-unlimited.net
  no update-callerid
voice register dn  1
translation-profile incoming SIP_Passthrough
number 201
call-forward b2bua busy 399
call-forward b2bua noan 399 timeout 20
call-forward b2bua unregistered 399
name Ross Toner
no-reg
label Ross 201
voice register pool  1
id mac XXXX.XXXX.XXXX
session-transport tcp
type 9971
number 1 dn 1
dtmf-relay rtp-nte
username ross password W***************
codec g711ulaw
camera
video
Any Help would be greatly appreachiated.
Cheers
Alan.
johschaf
Level 4
Level 4
You will probably need to fix this with an ACL on your WAN port. This isn't so much an issue with the SIP endpoint configuration, but an issue with the network configuration on the UC itself. In addition, the registration of your SIP endpoint should still be controlled by the UC before allowing calls to be made.
The voice service voip trusted list only prevents call setups from the IPs not listed. Since the SIP phone isn't sending a call setup the call is still permitted.
Toll-Fraud Prevention Feature in IOS Release 15.1(2)T
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Hope this helps.
-john
johschaf
Level 4
Level 4
Hope this helps.
-john
Hi John,
Thanks for that I think it'll be an ACL Issue. I don't fully understand the acl so I have basic routing but never setup the acl. so I'll have to learn a little bit.
cheers
Alan
