Cisco Analog Telephone Adaptor
t_kilany_2
Dear Sir/Madam,
I have some confuse for which Cisco ATA I should order ATA186-I1-A or ATA186-I2-A?
I have captured the below text from Cisco web site:
"The Cisco ATA186-I1 and Cisco ATA188-I1 provide 600-ohm resistive impedance. The Cisco ATA186-I2 and Cisco ATA188-I2 provide 270 ohm + 750 ohm // 150-nF complex impedance. The impedance option is requested when you place your order and should match your specific application. If you are not sure of the applicable configuration, check your country or regional telephone impedance requirements."
This is exactly my problem, which one I should go for the 600-ohm or the complex impedance one?
Its almost impossible to get this information from the telephone service provider, is there any reference that I can use to till the right ATA to use in Saudi Arabia.
Tarik
You should go with the complex impedance (I2 in the part number) for Saudi Arabia.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
5 Replies 5
Marcos Hernandez
Cisco Systems, Inc.
Dear Marcos,
Thank you for the clarification.
Tarik
ghermant
I know that a document available on the Cisco Web site describes country per country the type of ATA impedance that should be ordered but after several searches, I cant't find it.
Does anybody knows where I can find it?
Thanks & Brgds,
Gael
Hi Gael,
I totaly agree with you, there is no place to find such document.
But when I try the following comand in Voice-port configuration
cptone {locale}
Country
cptone locale Command Entry
Country
Argentina
ar
Lebanon
lb
Australia
au
Luxembourg
lu
Austria
at
Malaysia
my
Belgium
be
Mexico
mx
Brazil
br
Nepal
np
Custom 11
c1
Netherlands
nl
Custom 21
c2
New Zealand
nz
Canada
ca
Nigeria
ng
China
cn
Norway
no
Colombia
co
Pakistan
pk
Czech Republic
cz
Panama
pa
Denmark
dk
Peru
pe
Egypt
eg
Philippines
ph
Finland
fi
Poland
pl
France
fr
Portugal
pt
Germany
de
Russian Federation
ru
Ghana
gh
Saudi Arabia
sa
Great Britain
gb
Singapore
sg
Greece
gr
Slovakia
sk
Hong Kong
hk
Slovenia
si
Hungary
hu
South Africa
za
Iceland
is
Spain
es
India
in
Sweden
se
Indonesia
id
Switzerland
ch
Ireland
ie
Taiwan
tw
Israel
il
Thailand
th
Italy
it
Turkey
tr
Japan
jp
United States
us
Jordan
jo
Venezuela
ve
Kenya
Ke
Zimbabwe
zw
Korea Republic
kr
whereas {locale} one of the command entry in the above table based on your country, the output of that command does gave the answer.
on may case I have tried:
cptone SA
and I have got 600-ohm
Tarik
I think there is a mistake... Our internal doc shows for Saudi Arabia it is I1 and for South Africa it is I2.
Shameer,
World Wide Partner Helpline,
Cisco Systems.
Message was edited by: shameers
