02-09-2011 01:22 PM - edited 03-21-2019 03:39 AM
Greetings,
When we want to upgrade phone firmware for the 7941G ip phones, the instruction manual says to drop the ZIP package on the UC500 (we use UC540) icon in topology view, however, the CCA application does not accept any files. Are we doing something wrong?
Many thanks,
Pierre
Solved! Go to Solution.
02-09-2011 01:45 PM
CCA 3.0 does not allow for drag & drop of 7900 series phone firmwares. This is only supported for the SPA500 & SPA300 series phones. I do believe that drag & drop is on the roadmap for the 7900 series in future versions of CCA.
02-09-2011 01:45 PM
02-09-2011 03:26 PM
Thanks for that, are there steps to manually upgrade the phones?
Kind regards
Pierre
02-10-2011 08:53 AM
You can try this...
02-09-2011 06:42 PM
May I ask what phone load you are moving from and trying to get to?
We did implement D
02-13-2011 07:57 AM
Look on page 522 of the CCA 3.0 admin guide
This feature is supported, if you are having problems, then call into the SBSC
Drag-and-Drop Phone Upgrades (SPA500 Series, SPA300 Series, 6900 Series, and Selected 7900 Series IP Phones)
The drag-and-drop phone load upgrade method can be used to upgrade firmware for the following IP phones:
Cisco Model 6901, 6911, 6921, 6941, and 6961 IP phones (Model 6945 is
not supported)
Cisco SPA500 Series IP phones (including SPA525G and SPA525G2)
Cisco SPA300 Series IP phones
Cisco Model 7975, 7970, 7971, 7945, 7965, 7942, 7962, 7941, 7961, 7931,
7911, and 7906 IP phones
Look
02-20-2011 01:08 PM
Thanks for all the responses.
Pierre
