Hello,we got some new IP Phones CP8851-K9-V09 and I want to get them connected to our Auerswald Commander 6000R.Somehow this doesnt work at all because it keeps telling me (after reset ofc.)"Verify your service domain and internet connectivity and th...
Hello Community, I have installed a CISCO ATA191 and trying to connect it with the German Telekom Cloud PBX Environment.Device is not getting sucessfully registered. Please find below the last entries from the LogFile.Any Explanation about the meanin...
Hello: I belong to an all volunteer emergency communications group. We run our own PBX and use exclusively older Cisco phones for our volunteers. (like the SPA-2102, SPA-303, SPA-514, Etc....) I am trying to figure out how to lock the "Restricted_Acc...
Hello My spa 122 has a customization profile active and i want to remove it. But i don't know how to do it. Firmeware Update, Factory reset, disabling provisioning don't help.I tried to create a sample config file with the Cisco Profile Compiler but ...
Comparing an older SPA122 (v1.3.1 (003) ) and a ATA192 (v11-1-0MPP0401-002) the "Help" section in the top right corner of the GUI is missing. While I understand that I can use the admin guide and provisioning guide, why would they remove a help secti...
I am having a problem restoring a saved configuration on an SPA112. I create and save a backup using the web interface, then immediately try to restore it. The restore goes to 19% then stops and reports the restore failed. The device then reboots and...
I am functionally testing a Cisco ATA192 on firmware (11-1-0MPP0401-002 Oct 18 2020) and the 1st call waiting tone sounds like a staic-fax tone mixed with the phones regular ringtone and then the second CW tone sounds normal. I noticed that the CW1 c...
There is a way to transfer incoming calls by voip provider (registered in Lin 1 tab) to softphone in same network?
I have connected my softphone to PSTN (with sipaccount created in PSTN line tab and proper configurations for pstn-to-voip and voip-to-...
Hi I have a Router SPA122, and I need configure it with a Subnet Mask class B, the problems is that in the list of subnet masks only appear class C. What do I need to solve the problem?
Hello all,Could someone please advise me on how to set up the logs so I can analyse an issue with the device regularly losing its registration? System InformationSystem InformationName ValueModel:SPA112, 2 FXSHardware Version:1.1.0Boot Version:1.3.1 ...
Hello, I recently updated some spa504g phones form 7.1.3 to 7.6.2 firmware and I now the phones doesn't accept the Alert-info value in the SIP Invite.When the phones was on 7.1.3 I can set distinctive ring on it using the Alert-Ïnfo value on the SIP ...
Hi, I’m a novice to phone systems and have installed freePBX and Cisco SPA504G phones with Sipgate basic package. We have 4 phones, and one number, as we are only using Sipgate basic there is no trunking option from freePBX so each phone is set to ta...
I can’t seem to find any information on whether or not it’s possible to connect a line with multiple phones connected in series or parallell to one port on the SPA112/122.
This would be useful to connect a home phone network with 2-3 phones t...
