Cisco SPA509G to Cisco SPA509G
JohnHarris00
Is there a way to configure the phones (Cisco SPA509G) so that they talk to each other, like an intercom system?
Or configure them to talk to each other, IP to IP?
Basically internally we would have 16 Cisco phones, they would connect to a Cisco switch, a Linksys Router (WRT-54GL with DD-WRT) and then to a Satellite Modem.
This would be in Alaska, so the four to five second delay when it has to make the strip to the VoIP server back east can't really be done.
Would we need to have a Gateway device, like an Session Border Controller in play?
Thank you in advance.
John.
rbordner
John,
You are looking for IP to IP dialing between phones.
Have a look here:
http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a35a2c.shtml
It's a little dated but the concepts and steps are the same (the screen displays are updated on SPA50X phones).
The example is a Linksys PAP2
Randy
Thank you Randall, I'll give this a shot and let you know if it worked.
Anything I should be aware of trapfall wise?
Well I gave it a shot using both SPA509G's, and SPA-2102's.  Neither worked out.
Any advice where to go from here, Randall?
John.
Hi John,
Sorry you couldn't get it to go...  can you email me the config for 2 phones and I'll have a look.
rbordner@cisco.com
Any more input where it fails?  Could you place a call?
Randy
