Cisco UC540 incoming call problem
Thai Huynh
Hi everyone,
I have a problem with my UC540, below is my network diagram:
Internet---------887----------UC540
I have successfully configured UC540, incoming and outgoing call working perfect, but when I changed IP address on UC540's F0/0 which connected directly to 887VA then incoming call stop working??? outgoing call still work fine.
Example: I change F0/0 on UC540 from 100.168.100.253/24 to 192.168.1.254/24 then incoming call dead, if I change F0/0 ip back to 192.168.1.200/24 then incoming call work normal
Note: After int F0/0 has a new ip address, I have to restart the unit or it took long time for incoming call to work as normal.
          Even when ADSL2+ connection down for a few seconds only, incoming call still dead (will work again after Registrar time expired)
          I also noticed that after IP address changed, UC540 keep sent invite but doesn't received unless Registrar expired.
Forgot to mention that I'm using SIP Trunk. Configure file attached with incoming call setting only for easy to troubleshooting.
Please help and thanks in advance.
Tim.
5 Replies 5
ajay1komban
Dear Tim,
What type trunk connection , you are using there.
Please post your configuration
Ajay
Hi Ajay,
Config file attached and I'm using SIP trunk.
Dear Tim,
Did you change the session target of below dial peer,when you change  Ip address ?
dial-peer voice 1009 voip
 description ** Passthrough Inbound Calls for Internal Extensions from CUE **
 b2bua
 session protocol sipv2
 session target ipv4:10.1.10.1
 incoming called-number ^...$
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Ajay Jose K
Hi Ajay,
I'm only changed ip address on interface F0/0 by cml. I have updated more details about my problem with debug file included.
Tim
soloo2014
did you configure the 887 router or ITSP did that ?
because the ITSP will fix the traffic for the SIP to one ip , so you will need to check the configuration in the 877 router
another thing : in your example here i see 192.168.1.200 to 201
but in the configuration the ip is 100.168.100.253 ??
note that this ip is not a private ip address , if this IP is given to you by ITSP then you can not change it unless they approved.
