Cisco unity express 8.6.3 can't clean install 8.6.1 or 8.6.4 in UC560
Ming Tsung Wu
I have new buy UC560 device for cisco.
The CUE version is 8.6.3 in ISE module.
I can't find CUE 8.6.3 japan language package.
So i need to upgrade 8.6.4 or downgrade 8.6.1. But the hardware can't to upgrade or downgrade.
se-30-1-1-2# software install clean url ftp://X.X.X.X/cue-vm-k9.ise.8.6.4.pkg user XXXX password XXXX
WARNING:: This command will install the necessary software to
WARNING:: complete a clean install. It is recommended that a backup be done
WARNING:: before installing software.
Would you like to continue?[confirm]
Software install using RAM
Downloading ftp cue-vm-k9.ise.8.6.4.pkg
Bytes downloaded : 262258
Validating package signature ... done
- Parsing package manifest files... complete.
Validating installed manifests ..............complete.
- Checking Package dependencies... Service Engine Bootloader can not be installed on this platform/chassis combination.
===CUE Device Information===
# of Processors:              2
CPU:                          e500v2
Revision:                     3.0 (pvr 8021 0030)
BogoMIPS:                     133.12
SKU:                          Unavailable
UDI:                          Unavailable
Chassis Type:                 UC500
Chassis Serial:               FGL163610PT
Module Type:                  Integrated-Service-Engine
Module Serial:
Compact Flash:                2097MB
SDRAM (MByte):                1024
se-30-1-1-2#
===Device Software Information===
Installed Packages:
- Installer (Installer application) (8.6.3.0)
- ServiceManager (Multiple Service Manager) (8.6.3)
- Thirdparty (Service Engine Thirdparty Code) (8.6.3)
- Bootloader (Primary) (Service Engine Bootloader) (1.0)
- Infrastructure (Service Engine Infrastructure) (8.6.3)
- Global (Global manifest) (8.6.3)
- Auto Attendant (Service Engine Telephony Infrastructure) (8.6.3)
- Voice Mail (Voicemail application) (8.6.3)
- Bootloader (Secondary) (Service Engine Bootloader) (1.0.0)
- Core (Service Engine OS Core) (8.6.3)
- GPL Infrastructure (Service Engine GPL Infrastructure) (8.6.3)
Installed Plug-ins:
- CUE Voicemail Language Support (Languages global pack) (8.6.3)
- Madrox Multi-app Support (Multi-app support) (8.6.3)
- CUE Voicemail US English (English language pack) (8.6.3)
==CUE License Information===
se-30-1-1-2# show license status application
voicemail enabled: 12 ports, 12 sessions, 125 mailboxes
ivr disabled, no unexpired installed ivr session license available
se-30-1-1-2#se-30-1-1-2# show license status application
se-30-1-1-2#
==UC560 Information==
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
30 User Licenses
4 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
paolo bevilacqua
You can not not install ISE CUE software on UC500, but only UC500 specific CUE software.
And, (I don't know if that is the case), if the language you need is supported on CUE for ISR but not on UC500 CUE, there is no solution, and you can only complain to Cisco for not having delivered the languages they had publicily promised to the public.
Furthemore to that, it apperas there is a bug in 8.6.3 that makes so mailbox caller guide is played with default system language instead of user setting langiage.
paolo bevilacqua
Hi, Paolo
Thanks, I have found the CUE software for UC560. The Clean install is no prblem.
But  I clean install UC560 CUE software,
The software install script have show Japan Language item, But I don't find the software can download.
I need the Japan and Taiwan language package. like Cisco Unity Express Japan and Taiwan language package for ISR
As mentioned above. There are various languages that Cisco has promised (in a public presentation) for CUE, but never delivered.
Thank you for the nice rating and good luck!
