05-21-2011 05:08 AM - edited 03-21-2019 04:07 AM
Dear all,
after reading all discussion about network configuration of the UC320w, for me discovering of devices while setup is running as wizrd is not going.
We have for test procedure in our lab a New Cisco UC320W(firmware 2.6.10) and a ESW 520 poe-8port(firmware 2.1.19 and boot version 1.0.0.07) switch with 3 ip phones compatible with the UC320W.
We tried to setup the network with the 3 ip phoens and all of them get their IP address according to VLAN 1 and VLAN 100, but it seems that somthing is still blocking while the ssetup wizard try to connect all the devices( Getting Started with the Cisco UC320W Goal connect all devices wizard) no devices will discover.
We have setp the UC500 series in the past with success but this rsion seems to give us some problems, can anyone give me a solution to solve this problem.
thanks
05-21-2011 07:28 AM
Hi Earnest,
Below are several things to investigate further:
If you are still stuck, it is time to call the SBCS where they can interactively debug with you.
Chris
