Bookmark
Subscribe
1163
Configuration PAP2T
westlandict
I have a PAP2T and need to configure this to connect an doorphone (like an intercom).
But i got a problem with some settings that are not available in the configuration of the PAP2T.
FXS port Impedance: CRT21 <- This is the setting that i have to make.
On the PAP2T i only can choose between:
600
900
600+2.16uF
900+2.16uF
270+750||150nF
220+820||120nF
220+820||115nF
370+620||310nF
OnHook Voltage: 45V <- This is the setting i have to make.
On the PAP2T-EU i only can found... Ring Voltage: 85
Is this the same or must i have an other configuration?
Polarity Reversal: Yes <- This is the setting i have to make.
On the PAP2T i found in Line 1 > FXS Port Polarity Configuration > 3 options:
Idle Polarity: Forward
Callee Conn Polarity: Forward
Caller Conn Polarity: Forward
I have to set the Dial Tone till the Receiver Offhook tone on 440Hz
and Reorder Tone set to 50 (x10ms)
On the PAP2T i only see strange numbers and symbols, like...
Dial Tone: 350@-19,440@-19;10(*/0/1+2)
Reorder Tone: 480@-19,620@-19;10(.25/.25/1+2)
What all does that mean?? and how do i configure the PAP2T to set the Dial tone to 440Hz ?
westlandict
Below i mean the CTR21 setting...
For America you have 600ohms, for European there is the CTR21 setting, but this setting is not available...
600
900
600+2.16uF
900+2.16uF
270+750||150nF
220+820||120nF
220+820||115nF
370+620||310nF
