Counterfeit PAP2T???
jraymond4321
I ordered a PAP2T from ebay.  It shipped from Hong Kong.
After reading a number of posts regarding counterfeit devices, I wonder if this is also counterfeit.
There is a barcode label for both the serial number and MAC address on the back of the unit.  However, there is no numeric serial number or mac address printed.  It is just the barcode.  The numeric barcode translation is blank.  That concerned me.
One of the posts I read had a link to identify the company associated with the MAC address.  It was "Scientific Tech" something or other, not Cisco or Linksys.
Product Name:PAP2TSerial Number:FLI00F821056
Software Version:5.1.6(LS)Hardware Version:0.1.5
MAC Address:00173202671EClient Certificate:Installed
Customization:Open
Can anyone tell me if this is a counterfeit.   Or if there is a way to tell?
I can't get it to work with Gizmo5 and GoogleVoice, which is why I bought it.
24 Replies 24
spaceless
I recently bought a PAP2T from a Hong Kong ebay seller.
The label on the unit gives a MAC address which belongs to Joytoto Co. and the actual address from the web interface belongs to Science-Technical Cen.
Is this definitely a counterfeit unit or is there any way it could be genuine?
The paper labels on the unit also seem fairly crudely applied.
P.S. The serial no. printed on the label says FLI00G226125
but the serial no. from web access to the device itself is:
FLI00F820002
Can I tell my credit card co. that this is a definite fake?
MAC address according to the web access is
001732024000
(not the same as on the printed label).
Responses appreciated. Thanks!
Hi Spaceless,
To expedite the process of identification, please follow Patrick's instructions in his posting above.
Remove any sensitive information from the configuration of the PAT2T such as passwords or userID's, so you do not compromise your own privacy, and perform the actions as mentioned by Patrick above.  his reference  https://www.myciscocommunity.com/docs/DOC-9944
That information that you post will have all the details needed to identify the unit.  I personally have no heard of fake PAP2T.
regards Dave
Hi Dave,
Requested file attached.
Hi spaceless,
Please refer to my response to jraymond4321 at: https://supportforums.cisco.com/message/3095788#3095788
Patrick
I just received a PAP2T with the same serial number but different MAC.
Serial number: FLI00F820002
MAC address: 0017ADFD5C02
mjbad2pap2
I have almost same PAP2 bought from Hongkong. is it Fake?
Product Name:PAP2-NASerial Number:FH911EC02537
Software Version:3.1.22(LS)Hardware Version:0.03.4
MAC Address:00B30A010F03Client Certificate:Installed
Customization:Open
Hi mjbad2pap2,
Please check the MAC that you supplied.
Jason's coffer.com reports that it is an invalid MAC: http://www.coffer.com/mac_find/?string=00%3AB3%3A0A%3A01%3A0F%3A03
Please refer to https://www.myciscocommunity.com/message/29577#29577
If you purchased the device from a Cisco reseller, it is not fake. If you purchased it for a very low price or from a dubious source, all bets are off.
Patrick
Hi Patrick,  I also purchased the PAP2T from ebay. Item was shipped from Hongkong. It has SR. No. FH911EC00947 AND mAC ADDRESS 002A120B9986C( it was hard to read) I tried to confirm its mac adress from links given in this thread, but could not. Could you confirm it it is counterfiet or not.
parveenmalik73
Hi,    I also have been purchased PAP2T from EBAY. It was shipped from hongkong. Its Sr. No. is FH911EC00947 and mac address is 002a120B9986C( it was hard to read). I tried to confirm it's mac address from links given in this thread, but I could not. Could you help Patrik, if it is counterfiet or not.
