03-16-2010 11:22 AM - edited 03-21-2019 02:18 AM
ok guys ... I'm pretty desperate right now ...
what I did was I updated to the latest SW package UC520 8.0(1) using the latest version of CCA (2.2 I guess).
I left the config alone (I have a pre-upgrade copy of my startup-config as well).
after reloading the UC520 all of our phones are dead (most of them being SPA525Gs). they all hang at "connecting...".
sigh ... any ideas guys?
thanks,
Tom
Solved! Go to Solution.
03-16-2010 01:24 PM
Only other thing that I see in the posted config...
You don't have a load statement for the 525 and you don't have a tftp server command statement for that load.
But, the other phones that you have should have come up. I can help you look at the differences in the configs to see if that helps.
03-16-2010 11:22 AM
the update itself went smooth without any errors ...
03-16-2010 11:32 AM
Can you post a "show ip interface brief"? I suspect your vlan.dat file might have been deleted, making VLAN 100 dissapear. Did you do "Auto Disk Cleanup"?
Marcos
03-16-2010 11:34 AM
To expedite the resolution, and assuming your issue was that vlan.dat problem I mentioned, go ahead and type this in enable mode "vlan database", then type "vlan 100" and then type "exit". Again, in enable mode, not config mode.
Marcos
03-16-2010 11:39 AM
yes. i did a "Auto Disk Cleanup".
UC520#show ip interface brief
FastEthernet0/0 XXX.XXX.XXX.XXX YES NVRAM up up
In0/0 10.1.10.2 YES TFTP up up
FastEthernet0/1/0 unassigned YES unset up up
FastEthernet0/1/1 unassigned YES unset up up
FastEthernet0/1/2 unassigned YES unset up down
FastEthernet0/1/3 unassigned YES unset up up
FastEthernet0/1/4 unassigned YES unset up down
FastEthernet0/1/5 unassigned YES unset up down
FastEthernet0/1/6 unassigned YES unset up up
FastEthernet0/1/7 unassigned YES unset up up
FastEthernet0/1/8 unassigned YES unset up up
BRI0/1/0 unassigned YES NVRAM up up
BRI0/1/0:1 unassigned YES unset down down
BRI0/1/0:2 unassigned YES unset down down
BRI0/1/1 unassigned YES NVRAM up up
BRI0/1/1:1 unassigned YES unset down down
BRI0/1/1:2 unassigned YES unset down down
Vlan1 10.10.1.254 YES NVRAM up up
Vlan100 10.1.1.1 YES NVRAM up up
NVI0 10.1.10.2 YES unset up up
Loopback0 10.1.10.2 YES NVRAM up up
03-16-2010 11:44 AM
I see VLAN 100 is up. Can you try the commands I suggested anyways?
03-16-2010 11:48 AM
i tried as you suggested, and now the phones behave differntly.
or probably this is completely unrelated, but now the phones endlessly try to download various .xml files. seems like an infinte loop
03-16-2010 11:47 AM
Can you also post your config?
03-16-2010 11:49 AM
i'll be back in like 30 mins and will post my running-config then!
thanks,
Tom
03-16-2010 11:50 AM
No passwords and phone numbers, remember.
Marcos
03-16-2010 11:58 AM
We might need to make sure that the phones are getting the correct option 150 from their DHCP server. Also, do you have a different dhcp server on the network?
03-16-2010 12:37 PM
no, there is no other DHCP server on the network.
this is my running-config as it looks now. keep in mind, i'm in no way a cisco pro. i'm doing this stuff free of charge for my cousin who runs a very small non-profit organization. i just wanted to make sure that nobody thinks i'm earning any money by using their knowledge ...
thanks,
Tom
! Last configuration change at 20:32:03 CET Tue Mar 16 2010 by cisco
version 15.0
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.150-1.XA1a
boot-end-marker
no logging queue-limit
logging buffered 1000000
no logging rate-limit
no logging console
no logging monitor
enable secret 5
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 1
crypto pki trustpoint TP-self-signed-429973414
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-429973414
revocation-check none
rsakeypair TP-self-signed-429973414
crypto pki certificate chain TP-self-signed-429973414
certificate self-signed 01
quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip name-server 195.58.160.194
ip name-server 195.58.161.122
ip inspect log drop-pkt
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
isdn switch-type basic-net3
trunk group ALL_BRI
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
max-dn 56
max-pool 14
voice hunt-group 1 parallel
list 204,205
timeout 120
pilot 511
voice translation-rule 1
rule 1 /^$/ /204/
rule 2 /^0.*/ /204/
rule 3 /0/ /204/
voice translation-rule 5
rule 1 /REMOVED/ /150/
voice translation-rule 6
rule 1 /REMOVED/ /511/
voice translation-rule 10
rule 1 /^\(.*\)/ /00\1/ type national national
rule 2 /^\(.*\)/ /000\1/ type international international
voice translation-profile Tel1-BG_Called_6
translate called 6
voice translation-profile changeCalling
translate calling 10
voice translation-profile changeNullCalled
translate called 1
voice translation-profile fax_Called_5
translate called 5
voice-card 0
license udi pid UC520-8U-2BRI-K9 sn FHK133472JE
archive
log config
logging enable
logging size 600
hidekeys
username cisco privilege 15 secret 5
username bitbar password 0
process-max-time 50
ip tftp source-interface Loopback0
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address XXX.XXX.XXX.XXX 255.255.255.248
ip access-group 104 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone | cisco-phone | cisco-phone | cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch | cisco-switch | cisco-switch | cisco-switch
interface BRI0/1/0
description PSTN (1)
no ip address
isdn overlap-receiving T302 3000
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
trunk-group ALL_BRI 64
interface BRI0/1/1
description PSTN (2)
no ip address
isdn send-alerting
isdn static-tei 0
interface Vlan1
ip address 10.10.1.254 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.10.1.1 3389 85.126.77.66 3389 extendable
ip route 0.0.0.0 0.0.0.0 85.126.77.65
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
no logging trap
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.10.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny ip 10.10.1.0 0.0.0.255 any
access-list 101 deny ip 85.126.77.64 0.0.0.7 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 85.126.77.64 0.0.0.7 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 10.10.1.0 0.0.0.255 any
access-list 103 deny ip 85.126.77.64 0.0.0.7 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_15##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 10.10.1.0 0.0.0.255 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp host 195.58.160.194 eq domain any
access-list 104 permit udp host 195.58.161.122 eq domain any
access-list 104 permit icmp any host 85.126.77.66 echo-reply
access-list 104 permit icmp any host 85.126.77.66 time-exceeded
access-list 104 permit icmp any host 85.126.77.66 unreachable
access-list 104 permit tcp host 193.170.253.67 host 85.126.77.66 eq 3389
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip host 0.0.0.0 any
access-list 104 deny ip any any log
snmp-server community public RO
tftp-server flash:/7921-dictionary.xml alias German_Germany/7921-dictionary.xml
tftp-server flash:/7921-font.dat alias German_Germany/7921-font.dat
tftp-server flash:/7921-kate.utf-8.xml alias German_Germany/7921-kate.utf-8.xml
tftp-server flash:/7921-kate.xml alias German_Germany/7921-kate.xml
tftp-server flash:/be-sccp.jar alias German_Germany/be-sccp.jar
tftp-server flash:/gp-sccp.jar alias German_Germany/gp-sccp.jar
tftp-server flash:/ipc-sccp.jar alias German_Germany/ipc-sccp.jar
tftp-server flash:/mk-sccp.jar alias German_Germany/mk-sccp.jar
tftp-server flash:/tc-sccp.jar alias German_Germany/tc-sccp.jar
tftp-server flash:/td-sccp.jar alias German_Germany/td-sccp.jar
tftp-server flash:/its/germany_7960-tones.xml alias Germany/g3-tones.xml
tftp-server flash:/phones/5x5/spa5x5-7-4-3.bin alias spa5x5-7-4-3.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml alias Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
control-plane
voice-port 0/0/0
echo-cancel coverage 32
compand-type a-law
cptone AT
timeouts interdigit 5
timeouts wait-release infinity
description FAXLINE
bearer-cap Speech
station-id name Fax
station-id number 150
caller-id enable
voice-port 0/0/1
cptone AT
shutdown
voice-port 0/0/2
cptone AT
shutdown
voice-port 0/0/3
cptone AT
shutdown
voice-port 0/1/0
compand-type a-law
cptone AT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone AT
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 3004 pots
description Tel1-BG
translation-profile incoming Tel1-BG_Called_6
incoming called-number 0262223016
direct-inward-dial
port 0/1/0
dial-peer voice 1110 pots
description INCOMING FAX
translation-profile incoming fax_Called_5
destination-pattern 0262269676
incoming called-number 0262269676
direct-inward-dial
port 0/0/0
dial-peer voice 501 pots
description ** BRI pots dial-peer **
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/1/0
dial-peer voice 502 pots
direct-inward-dial
port 0/1/1
dial-peer voice 506 pots
description FAX TEST
answer-address 150
destination-pattern 150
incoming called-number 150
port 0/0/0
dial-peer voice 1001 pots
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts busy 4
system message XXX
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
user-locale DE
network-locale DE
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 501G spa5x5-7-4-3
load 502G spa5x5-7-4-3
load 504G spa5x5-7-4-3
load 508G spa5x5-7-4-3
load 509G spa5x5-7-4-3
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 299
max-conferences 8 gain -6
call-forward pattern .T
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6... blind
secondary-dialtone 0
fac standard
create cnf-files version-stamp 7960 Mar 16 2010 19:12:46
shutdown
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
max-calls-per-button 2
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description 302
name 302
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description 303
name 303
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description 304
name 304
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 10 dual-line
number 201 no-reg primary
label 201
description Piribauer
name Piribauer
call-forward busy 511
call-forward noan 511 timeout 120
ephone-dn 11 dual-line
number 202 no-reg primary
label 202
description Sommerbauer
name Sommerbauer
ephone-dn 12 dual-line
number 203 no-reg primary
label 203
description Dohr
name Dohr
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description Rehberger
name Rehberger
call-forward busy 205
call-forward noan 205 timeout 120
ephone-dn 14 dual-line
number 205 no-reg primary
label 205
description Bittermann
name Bittermann
call-forward busy 204
call-forward noan 204 timeout 120
ephone-dn 15 dual-line
number 206 no-reg primary
label 206
description BesprZ
name BesprZ
ephone-dn 16 dual-line
number 207 no-reg primary
label 207
description 207
name 207
huntstop channel
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn 18 dual-line
number 209 no-reg primary
label 209
description Johannides
name Johannides
ephone-dn 19 dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn 54
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 299
ephone-dn 55
number A801... no-reg primary
mwi off
ephone-dn 56
number A800... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address 0024.14D3.56BA
type 525G
button 1:16
ephone 5
video
mac-address 0021.A0D3.D130
ephone-template 16
username "bitbar" password
type 525G
button 1:14
ephone 6
video
mac-address 0024.14D3.5200
ephone-template 16
username "dohmic" password
type 525G
button 1:12
ephone 7
video
mac-address 0024.14D3.540A
ephone-template 16
username "pirkar" password
type 525G
button 1:10
ephone 8
video
mac-address 0021.A0D3.D292
ephone-template 16
username "rehdor" password
type 525G
button 1:13
ephone 9
video
mac-address 0021.A0D3.D21C
ephone-template 16
username "beszim" password
type 525G
button 1:15
ephone 10
video
mac-address 0024.14D3.567A
ephone-template 16
username "johkri" password
type 525G
button 1:18
ephone 11
video
mac-address 0024.14D3.5228
ephone-template 16
username "somman" password
type 525G
button 1:11
alias exec cca_voice_mode PBX
banner login Cisco Configuration Assistant. Version: 2.1 (1). Sat Nov 07 17:49:35 CET 2009
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login local
line vty 5 100
login local
ntp master
end
03-16-2010 12:49 PM
try this.
UC_540#
UC_540#
UC_540#config t
Enter configuration commands, one per line. End with CNTL/Z.
UC_540(config)#telephony-service
UC_540(config-telephony)#no shut
UC_540(config-telephony)#exit
UC_540(config)#exit
If that works, then do this.
UC_540#wr
03-16-2010 01:08 PM
no shut didn't do the trick.
i was however able to revert to a much older config which seems to work. thank god i keep the old IOS relases on the CF.
i have NO idea what happend though and why the config doesn't work with the latest IOS / software package.
Steven, thank you VERY MUCH for your more than competent support!
thanks,
Tom
03-16-2010 01:09 PM
i will compare the working config and the config i ended up with after upgrading line by line tomorrow and see if there's anything that catches my attention ...
