01-28-2013 09:19 AM - edited 03-21-2019 06:54 AM
We have a UC540 installed at the customer site and using SPA525 as phones.
When receiving an external call the number is displayed in the following way 00005251354780. When using the redialing function it comes to error due to that redialing isn't possible. How can we setup the system so that redialing is enabled.
We have to get rid of the first 2 leading zeros. How can we do that.
One zero is used to get the external line and the other to define the area code so the total number should look like 005251354780 or even including the country code then it should come up as 00495251354780. How can that be achieved?
Peter
01-30-2013 02:12 PM
no there is nothing like this in the config.
there are only this
voice translation-rule 1
rule 5 /^184020/ /21/
rule 9 /^18402/ //
voice translation-rule 10
rule 1 /\(^.+\)/ /00\1/ type national national
rule 2 /\(^.+\)/ /000\1/ type international international
rule 3 /\(^.+\)/ /00\1/ type any subscriber
voice translation-rule 50
rule 1 /^10/ /004952511840210/
rule 2 /^[123]./ /184020/
voice translation-rule 2001
voice translation-rule 2002
rule 2 /^A/ //
voice translation-rule 2222
I have made an translation test
this rule matches when i call the number
01-31-2013 11:03 AM
This is the translation rule need:
translation-rule 3265
rule 1 /^00/ /9/
It will translate this number to 9005251354780. If you use asteering digit other than 9, then just change digit in the rule.
-john
06-04-2013 10:38 AM
this was the problem the third 0 in rule 3 was to much. thank you all
rule 2 /\(^.+\)/ /00\1/ type international international
06-04-2013 12:49 PM
Note that all these rules can be written more concisely:
rule 1 // /00/ type national national
