Hi @m.castrigno,
You're absolutely right—many small businesses rely on shared hosting or hosted SMTP services where email authentication uses full email addresses (like user@my-domain.com). If CCA 3.0 or CUE 3.0 doesn’t support that format, it can be a major limitation for real-world use cases.
A great workaround is to use a modern SMTP service like SMTPWire, which fully supports authenticated email sending with info@smtpwire.com formats and works seamlessly with most applications—even on shared hosting.
You can check out their affordable and feature-rich plans directly on their website.
Hope this helps!
Best regards,
Mason Cartor
