Encryption of configuration files for spa5xx
dieswaytoofast
XML configuration files encrypted with openssl can be decrypted by the phone using the profile rule [--key “TheSuperSecretPhrase”] http://......
The issue is that if a user accesses the web-portal for the phone, he/she can glean TheSuperSecretPhrase through simple inspection.
Why not add an Encryption Key field under the Provisioning tab, which can be used as the Key (perhaps as $EK?).  You could have it as a text field of type "password", i.e., not displayable?
I know, you could use the GPP_S[ABCD] parameters for the same purpose, but the above suggestion has the added advantage of being an end-user editable field (much, *much* easier to do phone resets in the field!)
Mahesh Paolini-Subramanya | CTO | mahesh@aptela.com | 703.386.1500 Ext. 9100
2250 Corporate Park Drive | Suite 150 | Herndon, VA | www.aptela.com
Check out our Blog | Follow us on Twitter | Refer a Friend
0 Replies 0
