Experience long dropouts on my Cisco phone SPA525g
Brad Walser
Experience long dropouts on my Cisco phone SPA525g.
Please advise what we should try.
allen mert
Hi Brad,
Does your phone reset? Typically, a phone resets if it has problems connecting to the access point and LAN or to Cisco Unified Communications Manager. What status msg are you getting on your phone's screen display?
Check this out :  https://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g_7925gEX_7926/8_0/english/administration/guide/7925trb.pdf
1- Check wireless connectivity(wireless reception) first. I believe you are having network packet losses to your SIP server through wireless which causes call distortion,packet drops.
1- Check Layer-1 connectivity first. It sounds like your phone has network packet losses. Is it connected wireless? or PoE-ethernet? If wireless, please check the wireless reception at phone's location. And utilization on your Wireless AP. For optimum voice tranmission, RTT should be under 150 msec(actually this may go up to 200-250 msec, but Cisco recommends for better 2-way communication, RTT should be under 150msec.). Try to test wireless connection(check ping traversal timeto VoIP Signaling Server) with a laptop at the same location with phone-on desk. If PoE-ethernet, check your Layer 1 interface stats, do you see any increment on interface error stats?
If so, replace cable, check port settings(100,full),.
    32432 input errors, 12354 CRC, 0 frame, 0 overrun, 0 ignored
2- Do you have QoS setup throughout your Network which prioritize VoiP(SIP and RTP) in front of scavenger(PC untrusted internet,etc.) traffic? If so, check end to end QoS setup(should be identical on each Backbone-core-Access PoE switches)if you receive any dropped packets?
SC-3750X-Stack#sh mls qos interface gigabitEthernet 1/0/43 statistics
GigabitEthernet1/0/43 (All statistics are in packets)
  dscp: incoming
  0 -  4 :      100396            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0       438625
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0           26
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0    199308863            0            0            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :   434937527            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :     2050229            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0       401913
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :       42508            0            0            0            0
 45 - 49 :           0    187241996            0            0            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :   205874224            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :   435306714      2050229            0       401913            0
  5 -  7 :   187284504            0       336073
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           2           0   187287533
 queue 1:   434636617    23771515      336075
 queue 2:           0           0      400855
 queue 3:           0     2050229         754
  output queues dropped:
 queue 0:           0           0           0
 queue 1:           0           0           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Please rate if it helps..
Allen
This discussion has been reposted from Cisco Small Business Support Community to the SPA IP Phones community.
