Extension number Length
paulstocker
How do you change extension length from 4 digit to 3 digit?
sanjsinh
3 Digit Extension is supported from 8.6.3 release of BE3K. Unfortunately, once you upgrade to 8.6.3, there is  no easy way to change the extension length from 4 digits to 3 digits. You need to reinstall the system with 8.6.3 build and then select the extension length to 3 digits in First Time Setup.
Sanjay
sanjsinh
Sanjay
Thanks for the reply Sanjay, i suspected that would be the answer. I will re-install and then select 3 digits in First Time Setup.
Paul
