Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I am trying to configure the AA feature of the UC320W with a company system prompt. I need to configure the voice prompt of each menu by uploading an audio file of pre-recorded voices (Voice talents were used to create the company system prompt).How ...
pbergeot by Level 1
  • 2977 Views
  • 12 replies
I am trying to set up the SPA500S 32-button Attendant but having problems with the Attendant Key LED Patterns. I have found the codes to use (c=g, p=sb etc) but I don't know what to put in each option. Attendant Key LED Pattern Application LED:    Se...
Hi, we have a weird problem, probably a bug. It happens in 504G, 508G and 303. The thing is that after rebooting all the volume: handset, ringer, headset and speaker (in User) go to 0 in the phone but not in the configuration. If you call you don't h...
I have accidentally lost record of the admin password for a UC500, and I am unable to reset the admin password through the console - apparently No Password-Recovery (http://goo.gl/CtEwW) is enabled:line con 0  no modem enableDo I have any recovery op...
Hi I am trying to configure two SPA3102 devices which are on dynamic IP's (connected through Internet) to share PSTN lines of each other devices.Further it should be able to make terminal to terminal calls as well .(Like an intercom phone).Any help w...
